Courant Squir V2
Brought this rope from Honeys hoping to run my XX + Chicane set up on it in SRT. Slight problem is it slips! Not badly enough to make me think I'm gonna fall out of the tree but enough to make it impossible to work off of. Tried two different ZZ's, a Plus and a Gen 2 and neither liked the rope. Works great with a hitch set up though.
Anyone else had this problem?
  • 4 weeks later...
I had this exact issue when I first used the squire v2, but I was using an old (and apparently very worn!) ZZ. Swapped for the new style one abs hasn’t missed a beat since. Only suggestion may be, make sure your ZZ has had a proper good clean (I stick mine in hot water and clean with a toothbrush) as if the links are being hampered slightly it won’t grip so well?
