I had my seldom used strimmer serviced as it was not starting well and generally unwilling
as it lies in the shed with fuel in I bought some husquvarna fuel
it went well but next time I used it fuel leaking out
so back to dealer and new seals fuel lines required
councidence or down to fuel change ?
thanks
Down to fuel change. If you've run a tool on petrol for years everything soaks up the fuel and plastic/rubber swells a bit. If you put alkylate in it, it cleans the system out and takes all the absorbed fuel out leading to leaks and stuff. It won't happen again!
thanks
Yes . The rubber components have a coating on them to keep them supple . pump fuel attacks the rubber and removes the coating ( but in doing so sorta keeps the rubber soft ) Alkylate fuel will not attack the rubber so it becomes brittle after being attacked by the pump fuel . Now you have changed the rubber components you should be fine . If using Alkylate fuel in an engine from the get go this ,of course is not a problem .
