Brought the tractor up to check levels today and it looked a little lost at the side of the Landy bless it.
Tiny little tractor that works it's butt off
It was making a right rattling noise when I revved it, I thought the Hydraulic pump drive was stripping till I found a bird had tried to build a nest on the cooling fan :001_rolleyes:
Looks like it belongs on Ceebeebies Dean :001_tongue:
Could of swept the base plate before carting it over from the woods.
How long you had that winch on the landy, any problems with it?
Cheers
D
I was kind of hoping the chippings would fall off the base before I got home :biggrin:
Outstanding winches David, worth every penny, it has winched back 90ft heavy leaners on single pull no worries and as you may have seen, it gets used quite often with me
Good winches :thumbup1:
nice wee tractor. would love something like that for round my place. the goodwinch on my landy blew up in shower of sparks today trying to winch out a big flax grass that had been wrecked by the snow. might have been the big flood i went through on fri
did you check the direction of rotation on them anacondas dean? or do they work best in reverse for your drive? not bein arsy but usually directionals are t'other way round, Ed
They are on the right way Ed
You might need to check you haven't put yours on the wrong way :laugh1:
