Guest Gimlet
That flashing is going to leak. It's clearly a bodge. You need an independent HETAS inspection of the work. If it's condemned forward the report to Building Control.and keep a file of everything you do and every cost you incur.
If the installer is not HETAS registered but told you he was, he has basically committed fraud. There is comeback from this and you should pursue it. If the installer is, or claimed he is, HETAS registered you should get in touch with HETAS themselves in the first instance.
If he was not registered, they will be able to advise you on what to do next.
https://www.hetas.co.uk/consumer/complaints-policy/
He might be in Scotland though.
