Hi guys, This site has been recommended for me to try and find out the make and model of my wood burning stove? I would be so grateful if someone could help me, I have trolled the net but can’t quite match it. It needs new fire bricks and I don’t know which ones to buy. ( apparently they are all different) thank you so much. 🙏
If you are struggling to find out what it is, my fire bricks are 1" thick, 25mm and that seams to be a standard. Then you need 3: 1 across the back and one along each side, at a height roughly 2/3 of the height of the fire box.
Mine has a 45 degree chamfer at the back 2 corners so that the bricks lock together at the back and at the front there is a metal clip to hold them in place. if you can work out how far back the side bricks need to stop you can probably get some made up / buy off the shelf with that size / buy some board and cut them yourself if that helps.
Measure the dimensions and take off a few mm and you should be good to go like that.
Thanks, it’s good advice, and very kind of you to take the trouble. 🙏 After much research, I think it might be a parkray consort 15 or 9 , but if it is that stove, the fire bricks are very intricate, I’m just hoping there aren’t some vital bits missing too 😬. Well plus side is they’re supposed to be good stoves! Cheers Haydee
Hi,
A decent chimney sweep would be able to supply & fit the fire bricks for you if your not sure. My guy told me that if I ever need them done out with his normal sweeping times to get in touch.
Hi, I can't help you with the make but we manufacture baffle plates and can cut bricks, both 25mm and 30mm, to your required sizes and angles. A pattern would be really helpful.
Let us know if we can be of any help.
Ash1
All things Morso and Clearview.
www.morsoheaven.co.uk
It looks very close. Have you found the spare parts for them?
https://www.hunterstoves.co.uk/parkray-spares
They show parts and dimensions for their stoves so you should be able to check the model and see if anything is missing.
