Lombardini not starting
Sabretooth
Good Morning,
Is there a decompression lever on a Lombardini LDW 602? Engine was running well and then refused to start. Fuel, solenoid, filters, glow plugs all checked/replaced. Compression 80psi on cylinder 1 and 190 on cylinder 2, odd that piston rings or valves should fail suddenly so wondered if there is a decompression lever that is stuck.
Any advice much appreciated!
