It is shown on the tank unit, it’s not the best to see exactly where it fits, however it is a stainless pin, if look at the pump gear you will see a channel cut around its diameter, the pin sits into this so as when the shaft rotates it reciprocates.  Turn the gear with your finger and you should see this.
ahh adw..you are my hero! You have no idea how many times I have take this thing apart, which is probably how it went missing in the first place!
The only problem is now how to replace this as I can't see it on the parts diagrams..
