Hi, I'm a bit of a newb so apologies!
Got myself a husqvarna 130 chainsaw to do some light work on branches etc I pick up now and again for firewood.
I've read the manual and had a look at few videos, but wanted to check I've installed the bar correctly. There's 3 holes in the bar 2 opposite each other and one separate. One is for the adjuster pin. Now it fits into the larger of the holes but I wasn't sure if it should go in there or into the smaller one! In the image below the smaller one is on the top of the bar but on mine it's on the lower half! If its not for the adjuster pin, what's it for? Chain oil? Any help appreciated!
Chain adjuster  as you says goes in one of the larger pair of holes. Small hole is for oil feed to chain, you say its on bottom of bar, it will be on outside(away from engine side) as its corresponding pair will be on inside at top.
Tension hole and oil feed hole are duplicated to allow bar to be turned over to even out wear.
Edited by htb
Cannot spell
The doubling up of the holes is so you can flip the bar from time to time to even out the ware . The writing can be anyway up 🙂 👍
