Anyone run a Husqvarna 525rjx strimmer, I run a couple of Tanaka 230 as a hedge cutter and pole saw and want to upgrade one to something better, can't fault the Tanaka been good but one is getting a bit long in the tooth.
So anyone run one as hedge cutter or pole saw.
I run the husqvarna pole saw and strimmer. Great bits of kit. Also use tanaka and have done for some years, also good as you say.
The only thing is, I would rather start using a battery pole saw of similar spec to the petrol. I've got the very long husqvarna battery polesaw which gets me up about 5 metres and its just as good if not better than the petrol machine. But don't need it that big for most pruning jobs.
