18 minutes ago, Macpherson said:
Yeah, if your used to the Dremel then the Granberg sharpener is a touch agricultural as it's not got the 30,000 revs and possibly not the same fine tolerances but by no means terrible, it enables you to get the angles spot on and all the teeth and gauges  identical on the milling chains, worth noting that the Granberg  1/8" or 3.2 mm burrs screw in to the arbour so Dremel bits won't fit but they do work the other way....I think Eze lap sell both.
It's also good practice with diamond cutting to lube with a little water if possible, the burrs will last longer.
At the end of the day everyone has their own preferences when it comes to tools, cheers.
Usually what you've already spent a fortune on 😁
I was just trying to work out what's best for my Dremel as like you say, something I spent a fortune on 😂
