I use a smaller plastic box but in short, you need some sort of box with a limited opening so you can put the saw in the box to clean it. You just need a suitable size box, large enough for the largest saw and to fit in your workshop!
You can pick up decent sized sand blasting cabinets for around £190. Why not buy one of those and fit a hose and a circulation pump? The sandblasting nozzle is just an air compressor nozzle anyway.
I used to have one where I used to work. It was a sand blasting cabinet converted to water but it had a pressure washer handle in there and a 200bar pump. Basically a pressure washer in a box
