Hello All
I’ve been asked to look at cutting some SRC willow. The area is not huge, but I can see it being very time consuming. The stools are carrying everything forms whips to 3“to 4“ stems. It looks very labour intensive cutting, transporting and logging up for a wood burning stove. I was looking at cutting all the growth off, then logging on site. The other possibility was to use trailer and grab to get the stems into the yard and, if I can find one locally, use a branch logger to process into a building for storage. A little concerned as to how much the Willow will mildew and/or sprout. Has anyone else gone down this route before? Or has any one got any recommendations.
Thanks in advance
How big is 'not huge'?
We had 10 acres of it. Tried doing some by hand and chipping and it took an all day to clear about a 50m strip.
Ended up getting a forage harvester in with special willow head. Took 6 hours.
Its utterly worthless as Firewood too. Where are you?
I planted a little boggy patch with various willows including some ‘biomass’ strains
Small bits thru branch logger into bags I trim of brashly tips so it is time consuming probably ok to put them thru whole
makes great kindling with a firefighter
larger bits in to logs
Wouldn’t want to just have willow in the woodshed but handy to get things going and cheer up the fire
if you were branch logging into bulk bags I think you would have to watch for mold
david
Thanks for the responses. The area is only half an acre, in Cumbria, planted as potential fuel and as a biodiversity area. The customer also burns mainly softwood, so the Willow wouldn’t get lonely. Really just trying to get a feel for the easiest way to deal with it, whilst still making a shilling.
Edited by Lost in the Wilderness
I have found Branch logging green is easier on the machine and the branches tend to cut cleanly
dry branches tend to shatter more leaving a lot of shards
I have cut mine at about waist height aiming for mini pollards
easier to re harvest in 5? Years time
also rabbit proof and giving shoots a help to compete with vegetation
don’t really think there is any way of making it viable in £ terms for the fuel unless you have excellent access across the site (unlikely)
perhaps client would like to help you with dragging and loping if he is an enthusiast
the felling part is the least of it
i can send you a pic of my area just started on it yesterday if interested ?
david
