  • 2 months later...
  • 2 months later...
Thread tittle as a wrong name in Flow should be Control.
So got another Petzl rope this time is Flow 1.6mm and as bad as the previous, 1 first meter  is very bumpy.
My splice seems way better then Petzl, tighter eye, which hasn't moved, changed or deformed after 5month use, just a bit to big for passin the ZZ.
I am very happy and will do it again, when used enough I going to cut open my splice to compare with Petzl's
