Husqvarna 165rx, 265rx brush cutter differences?
1954???????? Bloody hell, I guess this is a typo? it may well be the same unit , you will need to remove the flywheel to check which unit it has, many 165s did have the sem unit, it will have sem on the flywheel.
Yes typo 1974
thanks
6 minutes ago, Byndy said:
And what about the 165R? In what was better the 165rx then the 165r?
I don't know about the 165rx as I only had the one 165r and then moved on to little Husky 240s, I still have one. I then went for Stihl  FS380 which is the one I mainly use with a shredder blade.
