hi guys......a v belt broke and snapped the line from the external grease nipple to the grease nipple on the bearing.... can't find anything on the parts manual for its size...looks like 5 or 6 mm,,,,has anyone replaced 1........cheers g
Not replaced one on a chipper, but we just get self assembly ones from hydraulic hose supplier for forestry kit. You could use section of old one and fitting for a pattern.
got 1 end off....its 5mm x 1 mm nylon ....check local tractor dealer. may have some
