I had a 2014 Hilux 2.4 until recently. When I got it it had one battery. I installed a winch. I also installed an extra battery and a T-Max charge box to look after the batteries.
I just replaced that Hilux (because I wrote off the old one - don't ask) with a 2014 3.0 which has two batteries installed already. Do I connect the winch to the battery at the front or the battery at the rear of the engine bay?
It'll make no difference! Which ever is easiest and crack on
15 hours ago, miker said:
It will have a split charge so either one
i have one with the dual battery,the front battery is connected to the winch,and the back battery is on the dual system,connected in series,i have been told the back battery is primarily to help starting the vehicle,this is the 2.5 hillux.hope this is of help adam.
