This part on my 230 is leaking hydraulic oil. A parts diagram seems to show a couple of o rings.
Anyone know if this will fix it rather than spending over £300 on a new part?
It could simply be the bolts sandwiching it together coming loose.
I’d get it off and strip if apart - more than likely it is something easily (and obviously) repairable.
Once in bits if there is anything you aren’t sure of, give flowfit a ring/send them some pics and they will be able to supply any individual components.
Is it leaking between sections? If so then it looks like a c top 3 valve and there will be 4 o rings between sections
Thanks guys. I’ll take it off for a closer look.
Cheers [emoji1360][emoji1360][emoji1360]
This is where it was leaking from, end part had snapped off probably when the bracket broke.
Bracket welded back up and another cylinder scavenged from Green Plant.
All fixed for £30 [emoji1360][emoji1360]
