ID please
On 22/06/2020 at 22:44, Essex said:
Is that a hot or cold smoker?
Hot and cold.
It is a gravity smoker, there is a large chute on the top right that you fill with charcoal. Bottom right, near the dally, is a door at the bottom of the chute where wood is put in to burn.
The top and side doors to the chute are closed and air flow controlled with a ball valve and fan (comp controlled) which allows temps to be held to with a degree or so. Huge thermal mass helps with that to, I reckon 1/2 tonne ?.
Heat smoke moves from chute into cooking chamber and out the top.
For cold smoking I just place the smoke generator where the wood would normally go.
It can cook a LOT at once, there are 5 large cooking trays, each about 1m *70cn
