331824691_DSC007911.thumb.JPG.5f22d7f4d83fc3222561397256e12ee8.JPGI stripped down the bar oil pump assembly down on my old 350 for the first time today and noticed that unlike my other saws this one does not appear to have a bar oil filter? From what I can see there is a port through the pump body going to the bottom of the oil chamber from the pump head and that is it. Am I right?
Edited by Marlin.45
2 hours ago, spudulike said:
All saws have more of a strainer than a filter on the rubber pickup pipe, yours included!
Cheers Spud,
The problem is I cannot find a pickup pipe in the oil chamber? On my 044 there is the rubber tube and strainer. On here - nothing.
I will see if I can a schematic to give me a clue?
Edited by Marlin.45
There isn't a filter on the pick up pipe, there is a filter however on the bottom of the oil tank, you can just about get to it between the tank and the crankcase, it is retained by a Philips screw, turn the saw upside down to do it.
Cheers adw, I'll dive out to the barn and take a look now.
Just found the manual to and the 350 is a bit of an anomaly in the range?
