Hi,
Like many others I'm using this time to give the tools some love. Come time to do the kombi engine unit; it's a strong reliable engine that goes well but undoubtedly vibrates more than it did when new. Looking through the exploded diagrams on l&s engineers  (and using my own eyes) I can't find any AV mounts on it. There are a couple of small rubber lined sleeves which I could replace but I cant see it making much difference.
So my question is (if I wanted to go further), has anyone replaced the plastic sleeves that act like the shaft bearings, and if so was it worth the hassle?
Or is there something else I'm missing to replace?
I know many will think or say that a professional tool that has already done its stint on the front line should be retired and replaced with new and reliable, which I don't disagree with, but given it's still a super reliable machine I thought id explore the options...
Thanks in advance.
Michael
Thanks lsEngineers for the fantastic diagrams
Try wrapping Hurley grip tape around the hand grips. Adds a bit of padding and absorbs a lot of vibes. I've used it on a couple of older saws and it helps, has a tendency to lose adhesion after a while so use a spot of super glue at both ends and it'll hold for longer.
That's a good idea, something like this
Fowong Self Adhesive Foam Tape 25 mm Wide x 3 mm Thick Closed Cell Weather Stripping Seal for Window and Door Anti-Collision Total 10M Long (2 Rolls of 5M Long Each)
WWW.AMAZON.CO.UK
Free delivery and returns on all eligible orders. Shop Fowong Self Adhesive Foam Tape 25 mm Wide x 3 mm Thick Closed Cell Weather Stripping Seal for Window and Door Anti-Collision Total 10M Long (2 Rolls of 5M Long Each).
Read more
