Hi all iv got a 200t that smokes ALOT! It’s like a thick blue cloud fresh 50:1 two stroke mix took the exhaust off piston has a tick layer of oil over it and the inside of the exhaust is thick wick black carbon what are the chances that the crankcase gasket has failed and is burning bar oil
Is the saw revving out to 13-14Krpm, if it is and your fuel/oil is mixed correctly then that is the most logical issue that may cause this problem.
You could empty the oil tank, flush it out, remove the bar and chain then fire it up and see if it still smokes.
Most two strokes smoke a bit when cold but clean up once warm.
