Could use a little help here please. I have a TW 230 DHB which needs an anvil replacement. I found the three capscrews that retain it and the removal thread (jacking screw?) does anybody have service manual for this machine?
Hi - you can view and download the TW 230DHB manual on the link below:
If you need any advice please get in touch with your local Timberwolf Depot (listed on our website)
TIMBERWOLF-UK.COM
Download the official manuals and parts lists for your Timberwolf Wood Chipper or Wood Shredder. Current and Historical machine manuals available.
  • 1 year later...
Hi just replaced the handbrake on my 230 it seems to come up a little high when in the on position, the owners manual doesn't cover handbrake adjustment or set up, is there a workshop manual available please? Thanks.
Depends upon the axles but generally you will either tighten a bolt on the back of the hub (knott axles) or click an adjuster round with a screwdriver (alko axles). The wheel should rotate with a little bit of rubbing but not locked.
look for around 5mm free play on each cable. Handbrake lever wants to come up around halfway.
Edited by doobin
