Had a problem with the chipper miss firing whilst under load, had the same issue about a year ago and changing the fuel filters out sorted it.
I'm going to replace the fuel pipes and do the filters again but having drained the tank theres a bit of fine grit at the bottom, just wondering if anyone has cleaned the inside of the tank before and if so what's the best way?
Worth doing once a year,especially if you fill often from 5gallon drums.
just drain tank and flush a gallon af diesel though a few times
