10 minutes ago, alittletreefella said:
hello all.
New to forum
I have a ms 362 and run a 20 stihl bar and chain.
I was given a 16in  wartech  bar and 16 inch stihl chain brand new. the chain ill not sit on the sprocket correctly 7 slot sprocket
The driver count for the " wartech " bar is obviously different . To avoid any arse ache  determining the right number of drivers it may be easier to buy a Stihl bar . There may be other problems like the alignment of oiler holes and tensioner location . 362 is a dead lump of a saw but that is beside the point . ?
3 minutes ago, alittletreefella said:
67 dl on stihl chain. how do I know what the bar will take .
THANK YOU FOR ANY ADVISE GIVEN
Add one driver . If not enough add another ......See what I mean about arse ache ? ?
Hello and welcome,
So, examine the 16" Stihl chain for the cutter & DL number then ID it correctly so you can see what bar it fits to:
Go to https://www.chainsawbars.co.uk/chain-id-table/
Look at far LH column for Stihl chains and see if the pitch & gauge match whats stamped on your 362 20" bar (apart from the legth).
If the chain is in good nick then it may be worth getting a bar for it if the chain pitch and gauge matches, otherwise hang it up in your shed.
