A guy i work for has one of these, it wont start....so looking at fuel or electrical problem
So how are you supposed to get at the engine if it wont start as grass box needs to be in its raised position to get at the engine ????? no manual lift that i can see ??
great machine but poorly thought out for maintenance/breakdowns
Any thoughts ??
Cheers
Mike
Any thoughts ??
Cheers
Mike
I assume all fuses are ok?
Don't know the machine, but from the manual:
"If the engine or the battery are out of order, the grass-catcher can be opened manually: insert the key and sit on
the driver's seat. In this way the hydraulic valve is relieved. Push the button to open the grasscatcher
(fig, 5, n. 13) and open the grass-catcher manually. The battery is located under the grasscatcher
in the rear part of the machine (fig. 33, A). If it is out of order, the battery can be removed
and recharged."
http://www.grilloagrigarden.co.uk/operators_manual/fd450
hmm, it had an issue with the main fuse when he first got it, ill chech that, cheers mate
I don’t know this machine but assume it’s a diesel with the d in model number. The diesel mowers I’ve used have a separate fuse for fuel solenoid. So if it’s turning over it could be that
No mate , its 22hp briggs petrol engine, 727 ? i think
it only has 40 hours on the clock..no end of problems but he seems reluctant to get on to the dealer. you cant tell some people !!
That’s weird. I wouldn’t even be bothering to look at it the dealer should be sorting it out
  told him it should go back, hes 87 and  pretty stuck in his way bless him, ive worked for him for 22 years and nothing surprises  me lol. i might try and convince him that it needs to go back to the dealer
Yes fair enough. The other option is all the safety switches being pressed in as they should be. Seat/hydro pedal cutting switch off etc
