Dolmar engine racing...any ideas?
Magooligan
Hi
I have a old Dolmar 116si, amongst others, which I bought as a job-lot. So I cleaned it and checked out the obvious, fuel delivery and spark. It took a bit of work but got it fired and ran but over a few seconds it's revs built, to say half throttle speed.  Its now warm, not on half throttle, both mixture screws are within the correct range and when I wound the tickover screw right off it was still racing. I fitted an identical carb of a nice running saw (Dolmar 120si) which did exactly the same (and obviously it doesn't do that on the 120si.  So I think I've eliminated the carb as the problem.  Do you think I'm looking at air-leaks, ignition timing, both or something else....what do you say?  At least it gives me a distraction from trying to fathom out how this 2 rope thing is going to go!!
Thanks folks! ?
Read more
