14 minutes ago, doobin said:
You run a 3/4 step down too? Best of both worlds
Not very often it’s used as a 3/4 tbh.
Apparently it’s exactly the same internally as the 1/2 inch driver anyway. I only went for 3/4 inch as I’ve got a big Bahco socket set that is essentially a full-body workout to use for anything - at least now I’ve got this I’m more likely to open that particular box to find a suitable tool when necessary!
Yes Screwfix are nearly always dearer for branded tools than Ebay or Amazon
You need 1000Nm because fasteners are often corroded or overtightened requiring a nut busting torque way higher than book torque.
I suggest this - cheaper than the blue RR and done my Transit hub nuts ~450Nm. The world turns, or if you're bit dopey like me sometimes and forget to check the direction before pulling the trigger - the bolt head shears off.
2072487647_Screenshot-2019-11-17DeWALTDCF899P1DCF899N18vXRCordlessImpactWrench1x5AhBattNEWeBay.thumb.png.b1287d329a8125d41b3e0e098500fe08.png
@doobin @Rough Hewn
I tried the different tools today with 6inch screws into Oak posts and I'll admit I was surprised.
All Milwaukee fuel (brushless) M18 Gen 2 except the impact driver which is a standard older one:
Drill on screw setting: Failed
Impact driver: spun out half way at 28seconds
Impact wrench: 10 seconds
Drill on drill setting: 5 seconds and took my wrist with it...
I stand corrected ?
I'll probably stick to the impact wrench because it was the only way to get them back out and can be used one handed but, as said, the drill with a side handle is quite a bit faster.
  • Like 7
That’s what I found too- got the same Makita as Monkeys, but the 1/2” drive was similar price and physical size so made sense to just have an adaptor on the 3/4”
Edited by Matthew Storrs
12 hours ago, monkeybusiness said:
If they love you very much then they’ll get you one of these - pull the trigger and the world turns until the nut comes loose!!!
The specs is pretty impressive, a tad more 'budget' than I was expecting and a bit more than just DIY, but, I'll do my best to justify it when she finds it! Perhaps list it as part of the sons inheritance!?!
That makes three of us. Great minds think alike
