There is a difference between what you are allowed to use yourself that you own and what employees can use or you can lend to others.
Also a pull-stop or other method doesn’t stop them dead instantly & also it doesn’t disconnect the PTO drive to allow you to unwind yourself!!!! :001_rolleyes:
Any unguarded shaft has the capability to pull clothing in even if the shaft is smooth yet alone having a thread on it.
They would be safer if they were driven by a hydraulic motor which can at least be stopped instantly and or reversed or manually unwound.
What your really talking about which is sadly lacking in so many people now is some thing called COMMON SENSE.............but thats moden life i guess.
