What are peoples thoughts on fitting a harvester felling head to a excavator without a computer, Do not need the feed rollers or the measuring system just the main items
Short of having all the  functions wired up separately with solenoids etc and a heap of switches. it wouldn't work, which would cost more than what it would to fit the computer.
I had it done to a Kesla Stroke Head to run on my Kubota via the SVAB Control system already installed to run the Engcon.
I literally wanted it to cut some product from clearance jobs, measuring by eye or counting the strokes was near enough for the intended use.
I had it all done by John Craig via the Engcon Ec-Oil fully automatic quick hitch system, so I could literally drop the head on/off from the cab in a few seconds when required.
All functions were controlled via the rollers/buttons already in the joysticks.
Worked perfectly.
Eddie.
Worked perfectly.
Eddie.
Was the harvester or processor head ?
Thank you every one you have answered my question, Back to the drawing board and carry on looking for a second hand grapple saw but they are very hard to find, A new one is more than i want to spend as it will only be used occasionally so not cost effective
