I have a Kawasaki th23 hedge trimmer and even after replacing the tank, fuel pipes and filter and grommet it still appears to be leaking from either the holes in grommet where pipes go through or round the grommet where it fits in the tank.
Any help or advice in relation to this or where I may find help would be gratefully appreciated
Many thanks
Hey, have you tried blanking the pipes off and spraying soapy water around the grommets/pipes and then blow in to the tank from the cap and see where the bubbles come from. With all them new parts it could be a small crack in the tank.
59 minutes ago, spudulike said:
Most likely the grommet has shrunk
I would have said the same if it wasn't for the OP saying it was replaced along with new pipes etc.   I'm wondering if perhaps the wrong grommet, or it was damaged while fitting.
Edited by lurkalot
Correcting a major typo
