3 minutes ago, joshhsoj111 said:
To be honest I didn't check. I just knew that the rayco sjr use that engine and ignition
Is there a part number on the ignition switch?
If I was you I'd ring Kohler and ask if you've got the right ignition switch for the engine. Give them the engine number when you ring.
Edited by eggsarascal
