2 minutes ago, Conor Wright said:
58 minutes ago, Stubby said:
What about an Oregon Jet Fit head ?
Read more
That looks like a better version of what I've got, does it throw out the line if you get caught up in brambles or snag a twig?
No .  ?
1 hour ago, Stubby said:
I would not use anything else but,  hey ho , as you say its a personal thing . What was the problem you found ? .
I do a lot of strimming round lamp posts street signs etc and found I was changing line too often even using thick expensive line so went back to bump heads.
i still use it now and then if I get a clearance job with some 6mm Oregon line with teeth on it I forget the name it’s good but £70 a reel!
