If it's got a drain plug I use it, because the sump is usually shaped to make the bung its lowest point.  If it hasn't got a drain bung like a lot of modern small engines I'll suck it out with a vacuum pump.   Normally  I find if you suck it out of a vertical shaft engine with a drain bung, you'll find you can't get as much oil back in as you can if drained properly.  That tells you something, or it should. ;)
