Thinking of buying a new set of AUS pruning rods. I see on their website there is standard rods and there is 'rail rods' which are apparently a bit heavier and probably less likely to bend/flex when you have say more than 8 on at a time. Anyone tried these heavier ones, if so what did ya think of them versus the stock rods? K
Not used the rail rods. Sounds like you already know, but things get pretty ridiculous using 7 rods ( I only have 7) of the standard ones. Saying that not broken or bent any yet.
I used to think that the flexibility was a bonus at times! We used to regularly work with a dozen up! Each bag that we had used to have 24+ in each. I think we could field five bags a day at our best!
If slightly more rigid, I'm not sure that the weight would help!
 they bow when ya use more than about 5 clicked together.  Most i have had on is 12/13 but they were supported by resting on limbs as they went up which help greatly.
Edited by wicklamulla
mine are flaccid and require viagra!
