hi all in need of some advice my rotor pulley came off when the chipper was running been chipping with it all day is there any reason why or has it not been tightened up after new bearings was fitted any help would be much appreciated
Hi Martin is it ? you need to make sure that the two surfaces are clean on the taper lock outer surface and the inner surface on the pulley . but it sounds like the grub screws have not been tightened enough. Has the taper lock split ? If you need any more help I have qualified Timberwolf technicians you can talk to. Gareth of Green Plant 01483 235111
yes taper lock split thanks for the number iv got one from spectram but ill save the number for next time something happens
