I’m going down to Warwick on Wednesday to pick it up, do you use one? I’m looking forward to getting it as I’m going under with wood, I’m must have 200 tonnes in my yard and it’s increasing by the day.
Good stuff, i have been running splitta 360 for about 5 years now, for us it works great, it’s a very versatile machine, it’s the one that sees the most use and produces very high quality product which is very regular, and it’s built like a tank, what form is your 200 tonnes ? you will like it at fuelwood, did you buy the one with infeed conveyor ?
My wood is mixed arb waste, some will need breaking down first with a hydraulic digger knocker, no i brought the 3 phase but i may add on a conveyor, do you know how much they cost?
I would give Fuelwood a call, i know when they added it to one of mine they worked me out a deal, there is some fabrication and some hydraulic mods so it’s easier to do while the machine is there, they definitely feed better with the conveyor especially odd shaped split rings [emoji106]
I have the logs set to 10 inch, from what i see you will get 20% more volume through the machine in the same time and have less rings to cut, i can still put 8 inch through but sometimes we adjust the feed up a bit so they are a bit chunkier if shorter, if that makes sense ? what conveyor did you manage to buy Rob ? you will be rigging up a cleaner next [emoji106]
