I've got this lovely section of beech stem right from the base of the tree so lots of interesting grain...
When I started wood turning I was advised to seal the cut ends with PVA glue to slow down the drying process and avoid splitting. I have tried this on numerous occasions but the wood still splits as it dries.
Any suggestions?
Another coat of PVA?!
I've brushed one coat over this particular section of beech stem...
What are others using to seal/dry the green wood? Thanks
A log round is almost guaranteed to split eventually unless maybe if it is just a few inches diameter, but even then it may still split.  Some species may not like perhaps Sequoia, but Beech is very prone to splitting.  I would suggest doing the splitting yourself, so the log does not need to split.  Either cut it into two half rounds or four - then it probably won't split.  And keep it in a well ventilated place outdoors out of the sun, and it will dry slowly.
If you were hoping to keep the whole round and turn it using the full size your only chance is to turn it green, and then finish turning when it has dried.
