re sealing grapple rotator
openspaceman
37 minutes ago, briquette_seller said:
Seal kits are quite expensive, but it's an easy enough job.
Thanks Gavin, I take it you did one and only the seals needed replacing or were other bits worn and needed replacing as well?
I've two rams to reseal as well so will be ordering bits. The thing is a replacement rotator is £600 so if the bits cost more than 1/3 of new I may as well get new.
Seals only. Everything else seemed to be ok.
Phone Clark's at Dumfries, they're a helpful bunch.
