  • Replies 90
my literature is not bang upto date
but i thought the 570 ran on 3/8 bar and chain
and the first link from cheapmowers.com says it,s 3/8
the husky manual says its 3/8
so i dont think it will but see what it says on the sprocket as that will give you a definate answer if bar is wrong
the bar no you posted is for a 325 chain
sprocket says 3/8-7
The bar is the right one.
Its just the make of saw that is wrong.:001_smile:
dick
bar is wrong one definatly
ring them up
check the chain
either on box it will say 3/8 or see if it fits round end of bar or sprocket
dick
ring them up
check the chain
Nob
Personally I would keep the bar and bin the saw.
The bar in the picture does not cover the chain oil port you can see straight away that the bar is not the correct fit. on the bar will be stamped the chain size to be used with it 325 or 3/8 no disrepect mate if you have the user hand book with it should give you all the info you need to operate and maintaine your new saw , me thinks thay just slung the wrong bar into the box
i will be having a right go at them later
