Husky 560xp compression test
forest tink
1 hour ago, forest tink said:
Tried a more reliable  tester and this is what it came up with
If you don't have a leak causing a lower Psi than it should be (150 psi and up is common  ) then that saw has issues.
Muffler off time to inspect the piston if you can be sure the tester is trustworthy and you find no leaks...5 hard pulls over minimum .
