3 hours ago, dan494 said:
super easy if its the same as the 530, one bolt holds a cover in place, take that out and the anvil has a thread on it you can screw a long bolt into and pull it out, 15 minute job
it can be a bit stubborn to get out somtimes, its reversable too so may not need a new one. (530)
I got mine out easy enough with a flat screwdriver under it and bit of jiggling. Make sure the surface behind it is clean when you put a new one in, didn't realize mine had accumulated black crud and new one sat slightly forward so the blades were just dinging it
Cheers
Gonna have a go this week
[emoji1303]
