1 hour ago, spudulike said:
Don't know what you are doing to them, I have found one or two get blocked and you get a vacuum in the fuel tank but it is pretty rare and the breather assembly is used on most Stihl equipment albeit with the pipe connector on the back on the MS200T.
Nothing no one else doesnt lol.
just using the saw then you can see under the carb bit fuel leaking from breather
17 minutes ago, spudulike said:
Possibly someone using a piece of wire to unblock the holes and piercing the membrane:confused1:
Nope, totally untouched.
Dont play about with saws just use them.... then the breathers eventually  start to wheep
