3 hours ago, chainsaw starter said:
Hi all, hedge cutter still doing it, ajusted carb, check fuel filter.
As before .......tank vent ?
Yes checked that as well
When you say you have had the spark plug out does that mean you have changed it?
If not change that first, could be the coil if it isnt a fuel problem. The coil can get hot and break down, once cooled it works for a bit.
