Heeeelllllppppp please
Oli3108
Help please
Iv just got a cheap chainsaw for a couple of garden job
It was fine but now when I start it up it Reves on full power as if the trigger is pressed and the chain spins as if cutting
What could it be and how can I fix it
The saw is a homelite
I’m just the average diy guy by no means professional
Thanks
Throttle butterfly on carb is stuck open? Remove air filter Have a look down the carb throat and see if the second one is open or shut. Have had chokes stick on before. Or you may have a massive air leak. If brand new take it back before you start dismantling.
