Carried out a picus Test today on a 90ft poplar.  The bottom few feet of the tree was infested with old wood wasp bore holes, and being a poplar if that age we presumed it would have a degree of decay in there.
sound as a pound as it turned out
661D28FA-4D22-44F3-BD68-66B5B0DD360F.jpeg269D998F-1794-4988-8282-87C855E85D9D.jpegEEB19EFA-95E6-4ACB-AC1F-437976CF3425.jpeg3A6D2E69-7E8A-43F8-A23E-5D4E0523FF88.jpeg09AB63E1-D607-4BB2-8503-6EC52C286061.jpeg
Probably clear wing hornet moth exit holes.
Sesia apiformis
I've seen decay associated with these invasive holes (probably Ganoderma white type rot) so a bit surprised that the tomograph looks clean.
can you go cut it down for us so we can compare :D
Does this Picus set up have more than 16 sensors?
12 sensors it has.  That tree was measured at 14 points using 7 sensors.
I don't do that anymore :D
