I was going to say should be able to manage 10-15 holes a day 2ft deep on reasonable ground :biggrin: I've used post hole borers twice in 12 years of fencing first was an early sthil petrol one, no dead mans handle you had man each side put the throttle full on and stuck it in the ground, worked quite well til we hit a brick footing ended up with us both on the ground and the borer happily spinning away on its own :001_rolleyes: second time was a tractor mounted one and it just sat there polishing the soil and wouldnt pull itself in :sneaky2:
