A similar, but 7 ton petrol splitter uses a Briggs and Stratton 6.5HP vertical shaft engine - so you'd need one of them (or similar) some way to interface the engine to the hyd pump and maybe some other bits and pieces!  To be honest, if you can't work this out yourself then I doubt you've got the eng know how to do the necessary modifications.  As above, either buy a suitably sized generator (don't forget splitters have a high startup current) or sell it and buy a petrol splitter
Read more
