Hello guys and girls,
Had a large ash tree come down in a woodland and cant get chipper access.  Given its a woodland we are now thinking about cutting the tree into lengths and leaving against a stream banking which is at an angle of around 15 degrees.  Can this be successful if we hammer some rebar into the banking to hold the timber?  Cheers.  Cant leave the stem where it is as its blocking the watercourse and footpath.
I don't see why not but you'd need to hammer it in a good way!
Did similar years ago using long scaffolding poles.  Only different was we had a mini digger on site to really pound them down with
Iv done a fair bit of river bank revetment work in the past using alder trunks (which last well in water) I drove down timber poles a good 5ft into the riverbed and then secured the Alder trunks behind. I then used HI tensile wire to bind the trunks to the poles so they didn’t float away come high water. Worked well and backfilled behind with soil and willow so the willow would grow in and take binding the bank together.
Edited by Matthew Storrs
