diesel engine runaway incident
flatyre
Can be quite dramatic. Best case is it ran out of oil to burn as fuel and stopped running, before the engine cooked itself too much. You can pop a new turbo on it and you could be all good. Its a gamble I guess.
It is important to use the correct oil. Cheap oil for non turbo engines doesn't lubricate the floating bearings in the turbo properly and they break.
