Thanks for the advice, I will put one in, as you say not that expensive so why not. Having researched it and seen your pictures I hadn't realised they were that small. Also I had not really considered the crawl and move option. I only have working group but thats pretty slow. I will give it a go !
That Is a nice conversion you did on the 222 !
We run it on a valtra that has a utch on the pto yes when I used 1 on a mog it too had a air clutch which ment the shafts could turn freely when disengaged, the overrun just gives the transmission some protection from the flywheel mass should you drop the rpm quickly, I got 1 not too expensive from local tractor dealers when I built the quick chip which isn't too big and just slipped onto the input splines on the gearbox. 4c272b6dbeb43adfdeb20b6bbf5a41fd.jpg
Sent from my F8331 using Arbtalk mobile app
Is that a Pto reverse gearbox mounted on the frame? If so, where did you get it?
Yes. It is, it's a unimog one that came from Atkinson vos as they are about the most compact ones I could find that could still handle a decent hp.
